I got a Dell 486 - my ultimate 486 build log!
Reply 20 of 29, by JonathonWyble
keenmaster486 wrote:
Clearly you've never gotten a CD stuck in a drive before.
You're correct! I've never had a situation with an optical disc like this one. I just asked a little question about what the OP was doing with his disc tray.
1998 Pentium II build
Reply 21 of 29, by keenmaster486
Your day will come. Better stock up on paper clips.
World's foremost 486 enjoyer.
Reply 22 of 29, by derSammler
That CD drive is just epic. That eject button looks like you can use it to park your cup of coffee. 😁
Reply 23 of 29, by keenmaster486
Some work done:
  • Replaced malfunctioning 3.5-inch floppy drive; disconnected 5.25-inch drive for now because it has a mechanical issue (makes a horrible noise upon startup and won't stop) and I don't have a 5.25-inch disks to test it with
  • Replaced RAM with two 16 MB SIMMS for a total of 32 MB, seemed to fix the random sprite dropouts I had been experiencing with Keen earlier
Still can't get the CD drive to read disks. I will have to open it up and try to figure out what's wrong with it.
Reply 24 of 29, by keenmaster486
More work on this project and some more pictures!
  • Upgraded RAM to 52 MB (with two extra 8 MB sticks... I believe there is 4 MB onboard already) -- I tried doing 64 MB but my two other 16 meg sticks appear to be bad somehow, or perhaps it will not accept 68 MB of RAM.
  • Fully cleaned out CD drive and lubricated the eject mechanism... lens looks OK but the drive still will not read disks. Accordingly......
  • Replaced CD drive with a generic IDE one. Someday I will fix the "Multimedia upgrade" drive but for now I am using a different one.
  • Installed Windows 95 on second partition - nice. Works well so far
  • Set up on desk with nice keyboard and mouse setup
Some pics:
The attachment e6d474d0-c18d-45cd-a1de-7af4aaf837ba.jpeg is no longer available
The attachment 5a921d82-bb0e-4e58-8e35-f0b15bf9050e.jpeg is no longer available
Uh oh! I had forgotten to load SHARE.EXE. Doh!
The attachment d96c67bf-a661-4d3b-9d23-051685a9da63.jpeg is no longer available
Reply 25 of 29, by Caluser2000
I had a DVD burner last week whose tray wouldn't open, not even with a paper clip. Had to basically pull on the tray to get it open. Pulled it apart to see what was wrong. Nothing obvious so in the bin it went.
Reply 26 of 29, by chinny22
I found with my DX2/66 I didn't really need a CD drive as long as it's networked that is.
As long as you have a large (by 486 standards) HDD you can keep the OS and drivers in a separate partition. and once the network up you can transfer everything else over that.
This is how I kept the original CD drive in my 486 so it still looks original, just useless 😜
Reply 27 of 29, by keenmaster486
Well, I need the CD drive for CD games such as Titanic: Adventure out of time pictured above.
Reply 28 of 29, by chinny22
Many early CD games used the size as the copy protection, you may find simply copying the cd to a partition and runnning the installer from there is enough to have the game running direct off the HDD.
otherwise cracks my exist.
shsucdx is an option for dos, or Daemon Tools 3.4.7 fro Win95.
Benefit is much faster load times then a CD drive, but of course you do loose the nostalga of a CD drive spinning away, which i do admit has a certain charm about it.
Reply 29 of 29, by keenmaster486
Yeah, having a physical CD is just more fun!
