"Fat Face" Compaq Presario: why?
First post, by Badscrew
Hello, everybody.
I was able to pick up this computer really cheap as part of a hardware swap: a Compaq Presario model 4716.
It's a Pentium MMX 133 (note: need verify the frequency).
It's in fully working condition, all original except the hard drive that was replaced and some RAM was added on top of its integrated 16 MB.
What the hell they were thinking while designing this case: already it's big and awfully heavy (lots of thick steel!) - why did they feel the need to make it even larger with this horrific face plate?!!
Reply 5 of 71, by Jo22
why?
Well, it makes it look more like Dracula (because of the ruff)! 😁
Reply 9 of 71, by Badscrew
oeuvre wrote:
what onboard video + sound does it have? are you gonna add a NIC?
It has a S3 Trio 64 of some sorts (with 2 Meg of RAM) and I don't know what audio chip is there, ESS something or other...
I will add a NIC, not sure if it will be wireless or not. I've an old D-link wifi card lying around somewhere, I'll see if it works.
Reply 11 of 71, by Badscrew
oeuvre wrote:
or... if you're crazy enough, 120mm fan vents!
For this you'll need to cut through what looks like automotive grade steel casing. British automotive grade steel that is, but I'd still rather not 😁
Reply 12 of 71, by Ultrax
I bet this is the house it was intended to be used in
41.73 KiB
Ultrax
__
Presario 425|DX2-50|8MB|SB V16S|D622/WFW3.11 😎
Deskpro XE 450|DX2-50|32 MB|NT4.0/95
SR2038X|Athlon 64 X2 3800|2G|GT710 WINXP
Dimension 4400|P4 NW 2 GHz|256M|R128U AGP|WINXP
HPMini311|N270|2G|9400M|WINXP
Libretto50CT|P75|16MB|YMF711|WIN95 😎
Reply 13 of 71, by hardrivethrutown
Yes
Systems:
- R5 2600, GTX 1070, 16GB
- i7 950, GTX 480, 12GB
- C2Q Q6600, HD3870, 4GB
- Athlon 64 3500+, 6800GT, 2GB
- P4 3.2, FX55008X, 4GB
- P2 400, TNT2, 512MB
- P2 Xeon 400, Elsa PCI Video, 384MB
Reply 16 of 71, by liqmat
Badscrew wrote:
...why did they feel the need to make it even larger with this horrific face plate?!!
A funnel for derpy hands obviously.
1.97 MiB
Reply 17 of 71, by SirNickity
I don't know. That is exactly the reaction I had back when these things were common as dirt at all the office supply stores. Who designed this atrocity, and who saw that design and then green-lit it? Is it just a dish to focus the sound of the CD-ROM spinning up, or was the CAD guy a dilophosaurus?
I have no nostalgia for the era of bulbous cases. Ugh.. awful. The monitors were just as bad, particularly with the "ears" hung on the sides.
Reply 18 of 71, by DankEngihn
Also even better, the only power switch is on the power supply...
On the back.
There's also no reset button, so if Ctrl Alt Del doesn't solve your problem, you have to reach behind the computer (god forbid if you have it on the floor under a desk) and turn the computer off then back on.
Reply 19 of 71, by Badscrew
There were also Compaq sub-notebooks in the 90's that only had soft power button, no reset and no easily removable battery. When THAT locked-up you had to either wait for the battery to drain dry or to open the case with a screwdriver!
