My never ending Tandon 286 project
Reply 20 of 24, by Caluser2000
No it wont slow down your system. It for use on 286 class systems only.
You''ll not I'm not running smartdrv.sys either. That is because Zineth did some extra hardware magic on the 286LP Plus with regards to hdd access and it is not needed at all.
Reply 23 of 24, by GuillermoXT
Moravec wrote on 2022-09-19, 13:02:
Is the Power Connector standard AT or different?
A bit different but i remember you´ve got a picture with the pinout of a similar connector from a 386 model @Dosreloaded.de - could you post it here just in case there´s another member with the same problem? 😀
My Retrosystems:
PIII on GA-6BA running Win98SE
AMD K6 233 on GA-586HX with Win95
Tandon 286-8MHZ Running DOS 6.22 on XTIDE-CF
M326 486DLC + 4c87dlc (Dos+Win3.11)
ECS UM4980 AMD DX2 80 5V (Dos & Win3.11)
Reply 24 of 24, by GuillermoXT
Moravec wrote on 2022-09-19, 13:01:
I have a probably not working Tandon PAC 286 System - the Connector is for the prpriatory 5.25 FDD connection
Do you mean the male ISA connector?
My Retrosystems:
