Reply 20 of 21, by TehGuy
mrzmaster wrote on 2021-09-24, 20:09:I did pick up a modern PSU that has a 20+4Pin main connector. The board has a 20 pin. Can I presumably just leave off the 4pin part and it should work fine with no adapter needed?
Believe so, yeah. Even the startech 24->20pin adapters I use just leave those last 4 connected to nothing (and I only need those because my EVGA units are 24-pin and not 20+4pin, plus my boards like to put stuff around the ATX power input).
Win98+DOS: C3 Ezra-T 1.0AGHz / P3-S 1.26GHz, 128MB RAM, AWE64 + Orpheus + Audigy 2 ZS, Ti 4200, 128GB SD card
Win XP SP3: C2Q 9650, 4GB RAM, X-Fi Titanium, GTX 750
PowerMac G4 QS 800MHz + GeForce4 Ti4200, OS 9
PowerMac G5 DP 1.8Ghz + ATi x800 XT, Leopard
