First post, by Blavius
- Newbie
I finally got to setting up my IBM ThinkCentre S50 from 2003. I picked it up a while ago, and recently found the matching monitor. It's a nice throwback to the Pentium 4 I used to have back in 2001. The only downside is that it only has two PCI expansion slots, no AGP. For sound I put in a SB Live, that I routed through the onboard to use the jack on the front panel.
My main goal with this machine is to play RTCW, COD, Q3 and UT99. The screen I has a native resolution of 1024x786, and I'd like to run at that resolution at a decent framerate. So I need a GPU powerful enough to play those games and being PCI. I looked for the fastest GPU I could find, assuming that the power of the card would somewhat compensate the slower PCI bus (I have seen comments here and there that support this notion) and give me reasonable performance to ~2001 standards.
I found a PCI Radeon HD5400 with 512Mb. On paper this 2009 card should have more than twice the performance of a 2001 Geforce 3 (2.6Gpixel/sec vs 800Mpixel/sec).
So now I have:
Pentium 4, 2.66GHz
1Gb DDR
PCI Radeon HD5400, 512 Mb
SoundBlaster Live.
I've put XP on it, and a period correct driver (8.93/catalyst 12.1).
UT99 runs horrible on D3D, put pretty good on OpenGl, with large open areas running generally around 60FPS, with dips to 40, and spikes to 160 in indoor areas. Resolution 1024, everything high. All good.
RTCW however is a completely different story, outdoor areas float around 12FPS with indoor running around 20. Weirdly, there is no real difference between 1024 and 640, high detail setting or low. This is unplayable, and very surprising as I recall playing through this game back in the day on a P4 1.7GHz with a paltry GF2MX.
So what gives? Am I just completely unreasonable on what to expect from this hardware, or should it perform a bunch better than it does? Am I using the wrong drivers? Is the card too new?
