Reply 40 of 52, by ynopot
- Newbie
PcBytes wrote on 2022-06-20, 23:59:Nothing else fiddled with. You want to screw up your RAM settings in the BIOS, be my guest, nobody stops you from watching a crashfest because you thought faster and tighter RAM timings will get you faster operation on cheap SDRAM that's been slowly degrading after 20+ years. And not just cheap SDRAM, but also on qualtiy SDRAM sticks as well (Micron and Samsung).
I found my two RAM modules in the garbage. They are different. PC-100. Even they give me 2-2-2-5 timings. And it's stable
Just go and try what I'm talking about))
PcBytes wrote on 2022-06-20, 23:59:As for driver revisions, whatever works the most stable - VIA 4in1 4.43, Amigamerlin Voodoo drivers, standard RTL8139 drivers (for now, as I might give Intel a try, providing I avoid that NC3121 card which I am sure is pretty much done for), Maximus Decim's NUSB 3.6 for everything USB (and this includes both VIA's integrated chipset drivers as well as the USB2.0 card), and whatever Windows provides for the rest (which would be the OPL3-SAx soundcard).
Now you know that Viagart.vxd from version 4.16 (4.17...) is faster. He is stable
