First post, by srmeister
currentyl i am developing a 286 Mainboard, because i thought it would be fun, plus they seem to get more and more rare.
Tried to use new components as much as possible. The CPU is original. Right now i am using Intersil / Harris 286 at 25Mhz.
System specs:
- uses original unpatched IBM AT BIOS (circumvents speed check by changing timer speed while booting). i plan to support other generic 286 BIOS but its untested as of now.
- SRAM instead of DRAM, just for ease of use. Right now its 4MB at 10ns so zero waitstates.
- yes, chipset is implemented in FPGA.
- has 7 ISA Slots, frequency at 8,33 Mhz but can be changed.
- can use normal PS2 Keyboard (or AT Keyboard via cable adapter)
- option to use PS2 Mouse
- option to use microSD card as HDD
- BIOS and option ROM (XTIDE Universal Bios in this case) can be loaded via USB cable and are shadowed into RAM. I plan on option to shadow Video BIOS ROM too.
- can use ATX or AT Power supply and option to add negative 5V regulator
- can be installed in AT or ATX case. Keyboard connector is at the usual place for AT case.
Right now added ISA Cards are: Trident TVGA 8900D VGA card and generic Multi-IO card.
I would like to hear your opinion on it.
