Less is More, so I've started to remove what I can to make it look better!
Ive removed the top radiator mount along with its dust filter and I've also removed the front dust filter to give the case a cleaner look! (I won't be using this system often, so the lack of dust filters doesn't really bother me!)
The removal of the top radiator mount along with its associated dust filter allows allot more light into the case and cleans up its look!
Because the front dust filter sits in-front of the front case fans, it seems to add a "blurriness", which I don't like! So its removal also makes the case look cleaner and sharper from the front!
Once the build's complete, I'll contact my supplier to see if I can't purchase another tempered glass door to replace the steel back door, as this should further improve its looks and feel! 😀 (And allow even more light in!)
As a matter of interest, I've been pricing Coppermine T's and the extra 133MHz on the 1.13GHz variant seems to cost $100 more on average! AND THAT'S PER CHIP!!! (Just crazy!!!)
It's crazy how a 1.13GHz Coppermine T can be ALLOT more expensive than a 1.4GHz Tualatin!!!
