Reply 20 of 75, by megatron-uk
Just rigged up a quick and dirty test environment with a shorted PS_ON pin on the Pico PSU and an ancient Samsung VGA LCD I had in the attic. Using the 3.5" FDD power cable from the Pico PSU direct to J1 on the SBC:
PS/2 keyboard directly attached to the keyboard connector responds okay.
All seems to work fine. The BIOS had retained values, but (the battery) is soldered on, so that may be something to resolve before building the case around it.
https://www.target-earth.net
