First post, by jh1523
I'm trying to make MT32 sound work with Secret of the Monkey Island (VGA floppy version) in DOSbox. The MT32 emulation works beautifully with SotMI-2 (similarly, VGA floppy version) but in SotMI-1 I can only get PC speaker emulation and SB emulation to work, not MT32. If I turn off both PC speaker and SB but leave MPU-401 set to "mt32" in dosbox.conf I get no sound, whereas if I do the same in SotMI-2 I get MT32 sound.
Has anyone noticed this? Is there a solution? SotMI does not have an option to configure sound, it's supposed to detect and use what's available. And I know it works with a real MT32 module.
Reply 1 of 2, by 5u3
Did you apply the Roland patch for MI1?
Reply 2 of 2, by jh1523
Yes, however I had not realized that to get external MIDI sound I need to start the game with the "R" parameter. Now it works nicely. 😀
