Its not GPL'ed (well, the DosBox code is, mine isn't). My code is strictly under a Public Domain license. Since I have a wife and full time job, I don't have too much time to work on this project. If I had more time I'd be more thorough in posting both binaries and source. Moreover, this latest post was strictly made to get feedback regarding my optimizations. You're right though, I shouldn't violate the GPL, and I'll continue to try to post both the source code and binary when I get time.
As for the dropped partials, they aren't nearly as bad as they were when I wrote the original post. The problem is still in trying to figure out exactly how the MT-32 deals with partials when it runs out of them.
As for the slowdown... it was the order in how I was doing things. Here's some pseudo-code to demonstrate:
Old version:
CallbackRoutine {
for each sample requested
call getsample routine (this routine would then return a single stereo sample from all the notes currently playing)
next
New version:
CallbackRoutine {
for each partial playing
call getsample of partial class and generate the samples needed from that particular partial
next
Because I'm not calling the same getsample routine 32 times over and then reloading the pointers to all the notes and partials a gazillion times, I was able to save a ton in CPU speed. I'll be posting the source very soon.
