First post, by xan1242
Hi!
I am new in this forum and sorry for yelling for help already,but MUNT does not work in Vista/7 on my PC.Here is the screenshot.
Somebody help,please?
Reply 2 of 10, by ADDiCT
Use the forum search before posting questions. Here's a thread with more info about installing MUNT on modern OS's. If you're trying to install on a x64 OS you're probably running into the "unsigned driver" problem. Win Vista and 7 x64 don't allow installing unsigned drivers. There are workarounds for this, but they involve a rather complicated set of procedures. I'm sure you can find more info by googling "install unsigned driver vista" or similar.
Reply 3 of 10, by xan1242
I have 32 bit Vista and I want to use it with another emulator.(With Sharp X68000 emulator)On XP,it worked perfectly until I got a newer graphic card,then I had to move on to Vista(It's good as 7 now).But even on Windows 7 doesn't work.
Reply 4 of 10, by otrov
Exactly same thing on Windows 7 32-bit.
Here is report.wer auto-generated after this failure:
Version=1
EventType=PnPDriverImportError
EventTime=129277660115108315
Consent=1
UploadTime=129277660117483351
ReportIdentifier=0e370662-b54c-11df-ba77-0013f77bc8c7
Response.BucketId=470946154
Response.BucketTable=5
Response.type=4
Sig[0].Name=Architecture
Sig[0].Value=x86
Sig[1].Name=Win32 error
Sig[1].Value=00000002
Sig[2].Name=Inf name
Sig[2].Value=inf0.inf
Sig[3].Name=Driver Package hash
Sig[3].Value=3822fb7a4a77bc2d52d24688a5453cf679a24ce3
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=6.1.7600.2.0.0.256.1
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1071
State[0].Key=Transport.DoneStage1
State[0].Value=1
FriendlyEventName=Could not install driver software
ConsentKey=PnPDriverImportError
AppName=Driver software installation
AppPath=C:\Windows\System32\mmc.exe
ReportDescription=Windows could not copy all of the files needed to install this device driver software. This sometimes happens when the driver software was not designed for this version of Windows.
C:\Temp\MUNT>dir
Volume in drive C has no label.
Volume Serial Number is E88F-2219
Directory of C:\Temp\MUNT
01.09.2010 00:23 <DIR> .
01.09.2010 00:23 <DIR> ..
04.07.2005 01:35 1.088 COPYING.txt
04.07.2005 01:34 184.320 mt32emu.dll
31.08.2010 22:05 65.536 MT32_CONTROL.ROM
14.04.2003 23:14 524.288 MT32_PCM.ROM
28.11.2004 20:38 206 oemsetup.inf
04.07.2005 01:35 2.887 README.txt
6 File(s) 778.325 bytes
2 Dir(s) 126.851.100.672 bytes free
Any tips?
Reply 5 of 10, by RvLeshrac
Yes, I know exactly why it does that.
Ah, yes, now I remember.
Something to do with Vista/Win7 converting the INF and mucking up the paths, it looks in %SystemRoot%\inf instead of the directory containing the INF.
I think you may be able to change all the relative paths in the INF to static paths (In your case, '.\' should be 'c:\MUNT\").
Reply 6 of 10, by fdlchris
The INF in question (oemsetup.inf), contains no static paths, in fact, very little at all.
[Source Media Descriptions]
1 = "MT-32 Synth Emulator Files" , TAGFILE = disk1
[Installable.Drivers]
mt32emu = 1:mt32emu.dll, "MIDI", "MT-32 Synth Emulator"
[mt32emu]
1:MT32_PCM.ROM
1:MT32_CONTROL.ROM
There are no %systemroot% variables stored in the INF.
Reply 7 of 10, by sergm
Hi!
I've got a quick solution for this. WinXP inf manager creates automatically inf-flie of new format and places it in %SYSTEMROOT%\inf\MEDIAINF\INF0.inf
This can be placed in installation dir and used on Win Vista / 7 without a problem. x86 of course 😉
Converted Inf is attached...
Regards,
Sergm
    mt32emu.zip
    543 Bytes
    953 downloads
    Converted OEMSETUP.INF file for installing Munt on modern OS
