Reply 20 of 20, by mirekluza
DOSBox Moderator
wrote:In my case it´s caused by my joystick.
It says:
Using joystick X6-38V Dual Analog Rumble Pad with 30 axes and 327683 buttons.
I had this problem in my MSVC builds. There was a bug in DOSBOX - joystick inicialization (I think it is in sdl_mapper.cpp) was called inside of "assert" !!!
MINGW may be compiles asserts into release version, but MSVC not. The result was the above mentioned nonsense.
It is fixed in CVS (joystick initialization was moved out from the assert).
Mirek
