First post, by wyattwong
I type "cmake ." in the "munt" folder and got the following error. How do I fix it ?
CMake Warning (dev) at /usr/local/Cellar/cmake/3.17.2/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:272 (message):
The package name passed to `find_package_handle_standard_args` (PkgConfig)
does not match the name of the calling package (GLIB2). This can lead to
problems in calling code that expects `find_package` result variables
(e.g., `_FOUND`) to follow a certain pattern.
Call Stack (most recent call first):
/usr/local/Cellar/cmake/3.17.2/share/cmake/Modules/FindPkgConfig.cmake:45 (find_package_handle_standard_args)
cmake/Modules/FindGLIB2.cmake:7 (include)
mt32emu_smf2wav/CMakeLists.txt:17 (find_package)
This warning is for project developers. Use -Wno-dev to suppress it.
mt32emu_smf2wav/libsmf/CMakeLists.txt:25 (find_package)
CMake Warning at mt32emu_qt/CMakeLists.txt:115 (find_package):
By not providing "FindQt5Widgets.cmake" in CMAKE_MODULE_PATH this project
has asked CMake to find a package configuration file provided by
"Qt5Widgets", but CMake did not find one.
Could not find a package configuration file provided by "Qt5Widgets" with
any of the following names:
Qt5WidgetsConfig.cmake
qt5widgets-config.cmake
Add the installation prefix of "Qt5Widgets" to CMAKE_PREFIX_PATH or set
"Qt5Widgets_DIR" to a directory containing one of the above files. If
"Qt5Widgets" provides a separate development package or SDK, be sure it has
been installed.
CMake Error at /usr/local/Cellar/cmake/3.17.2/share/cmake/Modules/FindQt4.cmake:1314 (message):
Found unsuitable Qt version "" from NOTFOUND, this code requires Qt 4.x
mt32emu_qt/CMakeLists.txt:117 (find_package)
-- Configuring incomplete, errors occurred!
