First post, by DOT850
I am trying to get DOSBox .63 to run in windows 2000 to run qbasic so that it can access the game/parallel port. DOSBox should work, but it just flat out won't start. The windows closes really quickly and it says something along the lines of: exit to error: can't init SDL...::Create Device::Device not registered.
Any help would be greatly appreciated. Everything runs fine on XP, this has me stumped.
Reply 2 of 3, by Guest
thanks for your help. that was it, never would have thought that was a going to cause a problem.
Reply 3 of 3, by taiken7
I dont think we honour parallel port accesses yet.
That is to say Printer Redirection can occur to a file, but Dosbox doesnt
transmit/recieve to the real hardware (yet).
