First post, by Peter Swinkels
Okay, having managed to find a copy of PowerBASIC 3.5 (which in many ways is superior to QBasic/QuickBASIC/VBDos/GWBasic/etc. I started playing with its features. Many are familiar to me from the afore mention BASIC dialects. However PowerBASIC contains a few unique features and uses an unusual syntax here and there. PowerBASIC fortunately does have a fairly decent online help built in, however and this the point of this is whole post:
There appears to be no way to copy/paste (internal to PowerBASIC itself) parts of the online help to the editing window. QuickBASIC does have such a feature. Also unlike the former, PowerBASIC does not offer any option to print the manual or anything from the editing window. (If the latter were possible I would simply copy/paste into that and print from there.)
I don't think DOSBox has a feature to save text-based (TUI's) screens to a screen-capture file the same way it does save screenshots to *.png image files. Otherwise I could have used that method.
So I guess my final question is:
Does anybody reading this know of a DOSBox variant that allows me to copy/paste from a TUI into Windows, or perform a print-screen (old-school DOS did that when the user presssed the "Print Screen" button) to the printer. If I don't want to print to my printer I can probably have Windows redirect whatever I want printed to a file.
Anyone?
Do not read if you don't like attention seeking self-advertisements!
Did you read it anyway? Well, you can find all sorts of stuff I made using various programming languages over here:
https://github.com/peterswinkels
Reply 2 of 10, by Peter Swinkels
@calvero: that’s rather tedious. Only as a last ditch effort. Especially multiple screens.
Reply 3 of 10, by Peter Swinkels
@calvero:
Your suggestion gave me an idea! I made a modified version of my Memory Dumping TSR which I wrote a while ago and made a text screen dumping app!
    Scdmptsr.zip
    2.04 KiB
    77 downloads
    Always room for improvements to be made, but it works!
Reply 4 of 10, by _Rob
DOSBox-X supports copy and paste of text. You can copy a text screen to your clipboard for instance. It also supports TTF fonts in text mode, and higher text modes like 132 columns and 60 lines.
118.2 KiB
Reply 5 of 10, by Peter Swinkels
@_Rob: I will check it out.
@Anyone else: I am updating my text dumping app to have a few more useful features.
Reply 6 of 10, by Peter Swinkels
@_Rob: found it, it does copy all text to the clipboard. Nice!
Anyway, I am still going to update my text dumping app. I've already made several improvements to the existing code. (support for different screen pages, 40-column support, screen mode detetion). I am also going to add a feature where line-breaks can either be inserted or not. And there will be the option to append to earlier dumps.
That, and the code should be much cleaner when I am done.
Reply 7 of 10, by Peter Swinkels
Okay, I managed to get all the extra featured I wanted working. The code needs some optimizing (and a few other minor changes to the program itself) but the program works as expected.
F11 = No appending to previous capture.
F12 = Append to previous capture.
Shift = Disable line break insertion.
    SCRNDUMP.TXT
    17.81 KiB
    84 downloads
    I captured the entire PB35 keyword list! Yay!
    Scdmptsr.zip
    3.69 KiB
    72 downloads
    Needs some optimizing but works.
Reply 8 of 10, by Peter Swinkels
Final version for now:
https://github.com/PeterSwinkels/Screen-Capture-TSR
Reply 10 of 10, by Peter Swinkels
@Ringding:
This link: https://www.bttr-software.de/freesoft/screen.htm#screencapt - might come in handy! Thanks!
