First post, by Anhaedra
All the ones I've used so far have been very glitchy, or just won't work at all.
"Please flee in terror in an orderly manner."
Reply 1 of 5, by MiniMax
Rank Moderator
Moderator
DBGL
_________________
Reply 2 of 5, by rcblanke
Would be very interesting indeed to know if you can get DBGL to work on OSX. I have an old G3 myself and got it working (sort of) after installing Java 1.5, overwriting the SWT libs and a lot of patience (this G3 is really too old). Unfortunately, while it seemed to work, a lot of SWT warnings and errors flew by in the console. I'm not sure if those are true bugs in DBGL, the hack I used to get JVM1.5 installed on my OS10.3 or problems due to the lack of speed of my machine...
The "DOSBox Preferences"-file is not supported (yet) for sure, but you might want to try generating a dosbox.conf inside the DOSBox executable directory and see if DBGL swallows that.
Reply 3 of 5, by IIGS_User
Let me introduce "Dapplegrey", a MacOS X frontend I worked on the last 4 - 5 weeks:
http://www.classics-for-x.info/csx/dapplegrey/index.htm
Supporting the most recent DOSBOX versions 0.65 and 0.70, it still missed some features which will be added in the future:
• Games Manager. Currently you've to navigate to your games inside DOSBOX yourself
• Importing existing config files
• Maybe a Terminal layer to see the DOSBOX output ("console")
It doesn't include a DOSBOX binary version, but you can set Dapplegrey to use both the officlal MacOS X port ("DOSBOX.app") as well as an extracted DOSBOX binary w/o. the application layer.
Created with REALbasic 2007r1, it should run on a G3 with MacOS 10.2.8, too.
Sent a msg to the DOSBOX team about this new frontend.
Klimawandel.
Reply 4 of 5, by abyss
Can dosbox run on a OS 7x or does it only run on OS 9X and later.
Reply 5 of 5, by IIGS_User
MacOS X only (version 0.70 = G4/MacOS X 10.4)
Klimawandel.
