First post, by wiltstilt
Hello, I'm trying to get Voyager's Ephemeral Films 1931-1960 to work on Windows 3.1 using DOSBox, I got an ISO from the Internet Archive. It appears to work fine up to installation, I just use imgmount for the file, nothing out of the ordinary - I've followed the exact same steps for other ISO files and it worked.
However, after it installs, I click on the icon and get an error message saying it "can't find Ephemeral Films CD". Any idea what could be causing this?
Thank you!
Reply 1 of 2, by BardBun
Try mounting it in Windows and then on DOSBox only add this:
mount d d:\ -t cdrom -usecd 0 -ioctl
Change "d:\" to whatever drive letter Windows assigns the mounted image file, i.e. "e:\" or "h:\" etc.
Change the number at "-usecd" to whatever number appears left of the assigned drive letter when you enter "mount -cd" into DOSBox.
Reply 2 of 2, by wiltstilt
BardBun wrote on 2022-05-10, 22:25:
Try mounting it in Windows and then on DOSBox only add this: […]
This worked! Thank you so much!
