First post, by 88rxn/a
😢 i been going crazy searching and trying to figure this out! if someone could please take the time to show me what im doing wrong?? im currently using a program that was made to run in DOS. i need ot load a file into this program while its on DOS. the program is for a standalone engine management sytem know as a HALTECH which looks like this: http://www.haltech.com.au/dos.htm now i have MAPS (preset fuel and timing configurations) to load into the haltech but i dont know how?? im not sure where to place the MAP exe. files so they can be loaded into this program while being ran in DOSbox? i am capable of running the system in windows without DOS and loading the files that way but i cannot connect the PC to the haltech without using DOSbox and i cannot save the MAP in the haltech program to switch it over to DOS box from windows.
so my question is:
is there a way to mount the MAP files somewhere so that i may load them into my haltech while using DOSbox??
thanks so much for looking and the time you took to help!!
trying to use DOS for haltech E6K on windows XP pro!!!!
