First post, by SpeechMan
I have a big problem. Everytime resolution changes while in fullscreen mode, I get CTD without error message. If I try to switch away from fullscreen I get a "dosbox.exe has encountered an error and needs to close". Anyone got a clue what may be causing this?
Specs are as follow:
Q6600
8800GTS 320mb (162.18 drivers)
2Gig 1066Mhz CL4
Win XP Pro x64
I know this may be cause the display drivers, but I hope not, cause I can't change to the beta drivers.
Reply 2 of 5, by SpeechMan
Well I have tried only 0.71 and 0.72, it occurs similar with both.
Reply 3 of 5, by wd
Rank DOSBox Author
DOSBox Author
Maybe try the various output= settings in dosbox.conf
Reply 4 of 5, by SpeechMan
Switched output to overlay, seems to work OK now.
Thanks for your help should have realized to try that my self *slaps head*
Well, hope this helps someone else with similar problems.
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
Maybe you can report back somewhen when new graphics drivers are
available for your card, if this solves the problem, too.
