First post, by stickymango
I am using a MacBook OS X 10.4.10 and I have figured out how to mount and make directories in the C drive. I downloaded some DOS games from mac.the-underdogs and when I tried to access them I couldn't.
For example, there's an icon for Treasure MathStorm! that's a snowball but theres a white "non" sign over it and when I click it it says "You cannot open this application 'Treasure MathStorm' because it is not supported on this system." Well then I tried using DOSBox to open it and the directory looked like this:
DS_STO~1 6,148 22-12-2007 4:51
TREASU~1 0 05-12-1994 9:31
TREASU~2 0 21-12-1993 7:00
But when I ctrl + click the icon it says: 4.8 MB where in the DOSBox it says it has 0 bytes. If anyone can give me some insight I'd appreciate it. Also, if I were to buy Treasure Mountain and it's system requirements state that it runs on OS: System 7.0.1 - 9.2 can I still play it on my OS X 10.4.10 with or without a DOSBox? Thanks
Reply 1 of 1, by IIGS_User
Usually you can't run Mac games in a DOS emulator.
You'll need a Mac emulator including ROMs and all the stuff...
Klimawandel.
