First post, by EvilJoven
I just recently installed DOSBox on 2 workstations. On the first workstation IPXNET.COM is on the Z: drive, on the second it isn't.
Copying the file to my mounted C: was easy enough.
Unfortunately, when I try to run ipxnet connect <ip of host> it CTDs.
Any ideas?
Reply 1 of 6, by wd
Rank DOSBox Author
DOSBox Author
same dosbox version?
Reply 2 of 6, by EvilJoven
Same version. Also, in case you haven't re-read my OP, running it from the mounted c drive crashes the dosbox window.
Reply 3 of 6, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
1. You have z:\ in the path variable, so it will work even from drive c.
2. set ipx=true in dosbox.conf to see the file.
1+1=10
Reply 4 of 6, by wd
Rank DOSBox Author
DOSBox Author
If it's not on the z:\ drive then you can't just copy around the .com file
from another dosbox installation.
Assure that the ipx setting is enabled in the dosbox.conf that is actually
used (watch the dosbox console window).
Reply 5 of 6, by EvilJoven
For some weird reason, even though it was set to false, ipxnet.com was showing up on my PC.
I set it to true on both PCs, working now.
Thanks
EDIT: now in the process of killing my wife with pipebombs, thanks guys!
Reply 6 of 6, by wd
Rank DOSBox Author
DOSBox Author
Hm hal was faster? You tampered with the system time 😉
