Reply 20 of 38, by Qbix
- DOSBox Author
I'm a bit puzzled what it tries to do here. Wonder if our seek on NUL matches that of real DOS.
60723059: FILES:Special file open command C0 file NUL60723060: CPU:Illegal/Unhandled opcode 6360723062: PIC:0 mask F960723064: PIC:0 mask F860723064: PIC:1 mask EC60723078: CPU:Illegal/Unhandled opcode 6360723097: DOSMISC:DOS:Unhandled call 5C al=00. Set al to default of 060723098: CPU:Illegal/Unhandled opcode 6360723106: DOSMISC:DOS:Unhandled call 5C al=01. Set al to default of 060723107: CPU:Illegal/Unhandled opcode 6360723120: CPU:Illegal/Unhandled opcode 6360723131: IOCTL:NUL:SEEK60723132: CPU:Illegal/Unhandled opcode 6360723140: IOCTL:NUL:SEEK60723141: CPU:Illegal/Unhandled opcode 6360723150: CPU:Illegal/Unhandled opcode 6360723194: FILES:Special file open command C0 file NUL
If you want to get deeper into this I can create a version that gives more info on those 2 calls and logs a lot more stuff.
Water flows down the stream
