First post, by sfuarus
Hi!
I haven't find such a topic, thats why I create this one if theres an answer somewhere please let me know it then delete this. 😀
So the problem:
When I press ctrl+alt+del (like to lock the comp) the DosBox close without a word. I've read about but havent found any similar problems. I've tried to run the Box as admin and/or in XP compatible mode but neither them help. Otherwise unless ctrl+alt+del the Box runs correctly without any problems.
Vista Business
DosBox 0.72
integrated updated vid.card Intel 946GZ with monitor resolution set to 1440*900
thx for the help
Reply 1 of 14, by wd
Rank DOSBox Author
DOSBox Author
Two possibilities:
1) don't run vista
2) don't press ctrl-alt-delete
Reply 2 of 14, by sfuarus
1) thats what is on the PC this moment
2) if u leave your computer unlocked at your workplace when you go somewhere thats your problem 😜
Reply 3 of 14, by wd
Rank DOSBox Author
DOSBox Author
Don't play games at your workplace then.
Reply 4 of 14, by gidierre
sfuarus wrote:
So the problem:
...interesting,
I'll check it tonight and report what will happen 😉
Reply 5 of 14, by sfuarus
thnx. maybe its just my Vista. it'll die soon if i cant manage to play continous 😀
Reply 6 of 14, by gidierre
ATM I'm on a WinXP machine...
but have you considered using vista suspension feature + a password, to block access & save state on hard disk ?
Reply 7 of 14, by MiniMax
Rank Moderator
Moderator
Tried changing the output=.... setting?
_________________
Reply 8 of 14, by gidierre
sfuarus :
here I am, I tried but have been unable to reproduce dosbox exiting so, neither ctrl+alt+del nor suspending Vista and then getting out of suspended state : each time dosbox is still there 😀
Otoh I have Vista Home Premium 32 bit and you have Vista Business and I have no idea whether this could interfere.
Have you tried to suspend ?
Reply 9 of 14, by Zachariah
No problems with vista premium (32 bit) here either. Beside, microsoft always claimed that ctrl+alt+del can not be seen by any other application but windows. If dosbox can do that, we did find something interesting. As well as it must be a vista bug.
Reply 10 of 14, by sfuarus
That's it! With opengl&openglnb it doesnt crash with any other choices it goes dead.
Gidierre: it did when i pressed ctrlaltdel, doesnt need any choice from the menu nor lock and unlock with passw.
anyway, thanks for the help. 😁
Reply 11 of 14, by sfuarus
damn! it works but its awfully slow. 😢
even the typing is slow.
tried with cycles put max but it doesnt matter nor frameskipping.
whats the solution for this?
Reply 12 of 14, by Qbix
Rank DOSBox Author
DOSBox Author
get decent opengl drivers (e.g not the ones from the microsoft website, but from your graphic card website)
Water flows down the stream
Reply 13 of 14, by gidierre
sfuarus wrote:
damn! it works but its awfully slow. :depressed: even the typing is slow. tried with cycles put max but it doesnt matter nor f […]
uhm... I never used opengl\openglnb that much myself, always ddraw, or direct3d, essentially for the same reason as yours : performance 😖
afaik it mostly depend on what graphics card & drivers one has...
with some cards for instance it happened to me openglnb was completely a no-go.
Reply 14 of 14, by sfuarus
Qbix: integrated video with the newest driver. i think the main problem the lack of videocard.
gidierre: i think ill cut short the problem and put an XP on the PC im not satisfied with Vista in other things too.
