First post, by whocrazy
Hi there. in the latest dosbox cvs, serial port support is broken. I am not able to use my text to speech synthesiser because it tells me the config strings in dosbox.conf are invalid.
Hope this can be fixed.
DOSBox version
Copyright 2002-2007 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file dosbox.conf
"vga" is not a valid value for variable: machine.
It might now be reset it to default value: svga_s3
"directserial realport:com2" is not a valid value for variable: serial2.
It might now be reset it to default value: dummy
MIDI:Opened device:win32
Thanks.
