First post, by paulp575
Just installed DOSBox and ran into a problem.
I followed the instructions on how to open the program manually by typing in the following commands:
MOUNT C "D:\SDX802"
C:
SOUNDEX.EXE
The program runs just fine.
Since I want to create a shortcut to run this program, I followed the instructions on the DOSBox Wiki page titled "DOSBox Shortcuts" by doing the following:
In the SDX802 folder I created a blank file SOUNDEX.XYZ
(I set .XYZ files to open using DOSBox).
When I click on the file, everything works except the last command gives an "Illegal Command: SOUNDEX.XYZ." (see attached screenshot).
So where did I go wrong????
Thanks,
paulp575
