Windows 98lite Working on DosBox 7.0 ^^
First post, by locazoo
Hi, i Just managed to make W98 run in DosBox, but i need to know what can of VGA driver can i install for be able to change resolution to 320x240x16 ( i will use it in mi PPC with DosBox 6.2 SVC ).
My questions Are:
- ¿What Kind of VGA card is emulated in DosBox (VGA Mode)?
- ¿Is it any other way to set windows 98 resolution useing the Generic Drivers?
Tnx.. ^^
Here Are some Pictures =)
    18.7 KiB
    Ok, This is How it Looks Win98 in DosBox ^^
    38.03 KiB
    Tnx to 98Lite
    55.82 KiB
    Here is My Problem.... ¬¬
    47.1 KiB
    Some System Information
    36.55 KiB
    I'd Like to change it to 320x240x16 T___T
Reply 1 of 14, by DosFreak
You could try QuickRes.
98 has never been very stable in DOSBox so unless you modified DOSBox yourself I wouldn't expect much from it.
Straight CVS 95B is the most stable.
Make your games work offline
Reply 4 of 14, by DosFreak
I don't think Windows 9x works in 0.63 although I could be wrong.
Yes, it's still an S3 Trio.
Also I think with plain CVS I've only ever been able to get 256 colors. Not sure if this is true with the latest CVS.
Reply 9 of 14, by IIGS_User
Freddo wrote:
TomCat39 wrote:
Would have been an interesting way to get Win9x/ME games working in XP. 😀
I've installed Windows 98 by using QEMU. Works fine.
That's the true way.
If you trust Microsoft you could also try Virtual PC 2007:
http://www.microsoft.com/windows/products/win … c/overview.mspx
Klimawandel.
Reply 13 of 14, by locazoo
Quick guide to install Windows 9x in Any DosBox Version.
You have to use a Hard disk image to propelly boot win95/98
to do it you have to create your Hard disk image, useing a bochs utility (bximage.exe).
Imput hd flat (size) and then note the Cylis numer ( for 50Mb HH is 101)
Load the image like this:
1)Boot a normal DosBox (disable all memory extensions)
2)imgmount 2 win98.img -size 512,63,16,406 -fs none ( note that the 406 are the cylinders you get when creating the image in bochs utility)
3)Donload and Dos 6.22 disk image and load it after mounting the img like this:
boot DOS622.img
4)After booting, run Fdisk and hit y and Intro to create a Primary dos Partition. Cloes DosBox and reopen
5) Now reload your .img like this:
imgmmount c win98.img -size 512,63,16,406 -fs fat (now use fat and specify a drive letter)
6) Boot again the 6.22 bootdisk image, then do a format C: /s .Restar DosBox.
7)Load the 98/95 image again (like in step 5) without booting the imagedisk and copy your win98/95 install files and copy them into the new HHD image in C.
8)After you copied the win instalation, boot the DOS6.22 image for example) then run your windows installation normally.
9)When system restarts close your dosbox, then use this:
boot -l c
This will boot your windows
or simply do boot win98.img
Then you can add to your DosBox Autoexec.bat this lines and it will Boot automatically ^^
Remember to disable the XMS and other memory extension from DosBox, or windows won't boot ( becouse windows loads it ows memory drivers)
Srry about my english!! Lol... I'm From Argentina.
Its a Quick Quick guide, may have errors, my apologizes..Hope this works for Those who doesn't kwnow how to make it work..
