First post, by d347hm4n
Hello,
I'm using DOSBox to run Legacy 16-bit code from 91 in Softgrid (App-V). It works very well and the program runs. But when I follow the menu choice in the program to exit, I am left with the DOSBox window open. If I click on the X everything closes correctly.
I am running DOSBox with a batchfile. I cd to DOSBox's directory and call the DOSBox.exe with the full path to the executable that I want to run.
Essentially I am asking is there a switch for me to close down DOSBox, or is there a way I can detect the program that is running inside of DOSBox in the taskmanager or can DOSBox tell me what is running inside of it.
I hope that I have made myself clear.
Reply 2 of 18, by d347hm4n
Ok thanks, but for others, you just need to pass in the -exit flag after the full path for the program.
Thanks, took me like 30 minutes to find that, could have saved me some time but nvm....
Reply 3 of 18, by Qbix
Rank DOSBox Author
DOSBox Author
I wrote the documentation in the hope that I didn't need to answer questions about things described there.
Water flows down the stream
Reply 5 of 18, by gpicht
Hello,
I'm a newbie here and have only first experiences with DOSBox and Vista - my favoured OS is still W2K.
The -exit parameter (or the exit in a started batchfile) is working fine in general. But I have one application, where I couldn't get it running right now. It is an very old DOS program system fur surveying calculations, which I have still in the production process.
The program system is started by execution of a batchfile and the calculations are choosen menuebased. Depending on the userinput some action starts, no chance to analyse the workflow between DOS-programs and automatically created batchfiles for those menues. Ending this program leaves me with a open DOSBox - even with -exit-parameter.
At this time this post is only a report of this effect, so please don't answer: 'read your manual'.
I still do so 😊 and try to analyse and find a solution.
Reply 7 of 18, by gpicht
The desktop icon starts with:
"C:\Program Files\DOSBox-0.72\dosbox.exe" -conf "C:\Program Files\DOSBox-0.72\dcs.conf" -exit
and the dcs.conf executes:
keyb gr
mount c c:\*****
c:
gusdcs
exit
where gusdcs is the batch-file
c:
cd \geodcs
gn
and gn is the next batch file, this starts menue and (sub)progs
You see, in this actual version I have '-exit' in startstring, 'exit' in DOSBox config-file and in my first batchfile. And the window remains open.
Edit: Sorry, in the first batchfile is actually no 'exit'.
Reply 8 of 18, by DosFreak
Think you need to use "call" on "gusdcs".
Unsure if "call" is supported in DOSBox. Only one way to find out....
Make your games work offline
Reply 9 of 18, by MiniMax
Rank Moderator
Moderator
Remove the -exit option. It only works when you launch DOSBox with a file.
gpicht wrote:
and the dcs.conf executes: […]
keyb gr
mount c c:\*****
c:
gusdcs
exit
Add a call before gusdcs:
keyb gr mount c c:\***** c: call gusdcs […]
keyb gr
mount c c:\*****
c:
call gusdcs
Or you can remove the exit command and the call to gusdcs from dcs.conf and launch DOSBox like this:
"C:\Program Files\DOSBox-0.72\dosbox.exe" -conf "C:\Program Files\DOSBox-0.72\dcs.conf" "C:\*****\gusdcs.bat" -exit
Then your dcs.conf should only contain:
keyb GR
mount C "C:\*****"
C:
_________________
Reply 10 of 18, by ripsaw8080
Rank DOSBox Author
DOSBox Author
If you're going to go with putting an "exit" in the top level batch file, you need to put "call" in front of all batch file "subroutines", so in gusdcs you need to change it to "call gn", and so forth, or it won't "return" back up the chain.
Reply 12 of 18, by gpicht
My problem is solved. As you said, a simple 'call gusdcs' followed by 'exit' in the conf-file closes the Box at the end. No need for -exit in the runstring and no need for modifiing the deeper (in my case unaccesible) batch-files.
Thanks again 😀
Reply 14 of 18, by MiniMax
Rank Moderator
Moderator
ripsaw8080 wrote:
because you would have to call it if it were a batch file.
No.
_________________
Reply 16 of 18, by MiniMax
Rank Moderator
Moderator
Did you try it?
bat1.bat
echo bat1
call bat2
bat2.bat
echo bat2
bat3
bat3.bat
echo bat3
db.conf
[autoexec]
mount C "."
C:
call bat1
exit
_________________
Reply 17 of 18, by ripsaw8080
Rank DOSBox Author
DOSBox Author
You're right, it does work that way in the specific case where the last command in a batch file transfers processing to another batch file. However, if you ever want to continue processing additional commands in any given batch file after running a sub-batch, you must add the CALL.
Reply 18 of 18, by MiniMax
Rank Moderator
Moderator
Absolutely 😀
_________________
