I was able to create a file dosbox.conf according the guidelines received. However I'm not sure to understand correctly the purpose of line output=surface
As I understand , this line must be modified to something else.
What should I type to replace the word "surface" ?
And what is the specific task of line
output=blablabla ?
As for the other guidelines there was no problem.
(The config wiki helps a lot as well)
Thanks again.
EDIT : The configuration file is being accessed correctly ; the section [autoexec] being executed when launching DosBox in Ubuntu.
But the window size is still about 1/4th of my 17" screen.
I want to scale it about 2/3 th.
I join the configuration file in attachment. What is to to change ?
Thanks
