First post, by ecksemmess
As far as I can tell, DOSBox has no provisions for playing emulated PC speaker audio on the host's actual PC speaker (correct me if I'm wrong, of course).
Just curious -- why not? And are there any CVS/unofficial builds or patches that add this functionality? There's nothing quite like an actual PC speaker, so I'd love to find a way to do this if possible, even if it means attempting to harness my meager programming skills to hack the source.
Thoughts?
Reply 1 of 8, by collector
Including the little piezo buzzer that all modern motherboards have in lieu of a case speaker, anymore.
Reply 2 of 8, by ecksemmess
Some of us have so much free time on our hands we've gone to the trouble of retrofitting our modern systems with proper case speakers. 🙄
Reply 3 of 8, by wd
Rank DOSBox Author
DOSBox Author
Not portable.
Reply 4 of 8, by ecksemmess
True enough, so I suppose it makes good sense not to have it as an official feature. I am a bit surprised if no one's patched it in unofficially just for PCs, though.
Reply 5 of 8, by wd
Rank DOSBox Author
DOSBox Author
Well i don't see any point for this, if the sampling rate is set high enough
and there are not too many bugs in the code, it should reproduce the
sound quite nice through the regular sound output.
Reply 6 of 8, by Harekiet
Rank DOSBox Author
DOSBox Author
Should just use a windows sound driver that plays your regular sound output through the pc-speaker, problem solved!
Reply 7 of 8, by DosFreak
Well most people like hearing better sound quality. Can't fault them for not wanting to listen to a POS PC speaker.
When I owned a 286 and all I had was a PC speaker I thought RealSound was the most amazing thing out there but it still sucked ass compared to the TV I watched movies on.
With DOSBox emulating the PC speaker you get much better sound quality but obviously if you want the exactly original sound you heard 15 years ago (although even that's not really possible because not all PC speakers are the same and your ears get worse over time), you'll either need to modify the DOSBox code or do what Harekiet suggests.
Make your games work offline
Reply 8 of 8, by ecksemmess
Yeah, thanks for that idea Harekiet. Hadn't thought of that. 😀
