First post, by SHP
Using the Cycles command inside DOSBox has no effect: they're permanently set to Auto, unless I use Ctrl+F11 and Ctrl+F12 to change them (which is annoying). Changing the default Cycles value in dosbox.conf has no effect, either. I tried a DOSBox CVS build, but the problem persists 🙁
Any suggestion about solving this problem?
Reply 1 of 10, by MiniMax
Rank Moderator
Moderator
And what is the real problem here?
_________________
Reply 2 of 10, by SHP
...That I can't automatically run games on the proper speed setting they need by using batch files, and using Ctrl+F11 and F12 is annoying and in many cases, not specific enough.
Reply 3 of 10, by lightmaster
create a config, then edit the cycles option 😀
Reply 4 of 10, by SHP
Thanks for the suggestion, but I already tried that to no avail. But nevermind, I just found a workaround: using an older version of DOSBox, or another CVS build. It seems like the bug appeared in the last DOSBox version.
Reply 5 of 10, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
cycles=fixed 50000 would be the command
1+1=10
Reply 6 of 10, by SHP
...It works now! 😳
So it wasn't a bug... Why did they change the line?
Anyway, thank you. I feel so dumb now 😜
Reply 7 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
why not ?
anyway get a recent cvs build and be happy
Water flows down the stream
Reply 8 of 10, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
you have to read what is written in the dosbox.conf file:
# cycles: Amount of instructions DOSBox tries to emulate each millisecond. Setting this value too high results in sound dropo […]
# cycles: Amount of instructions DOSBox tries to emulate each millisecond. Setting this value too high results in sound dropouts and lags. Cycles can be set in 3 ways:
# 'auto' tries to guess what a game needs.
# It usually works, but can fail for certain games.
# 'fixed #number' will set a fixed amount of cycles. This is what you usually need if 'auto' fails.
# (Example: fixed 4000)
# 'max' will allocate as much cycles as your computer is able to handle
sometimes, stuff gets changed because it makes more sens this way to the devs. But if it gets changed the commands are either documented in the readme or the dosbox.conf (or both 😀).
So next time, if something won't work anymore, look at those two (and generating a new dosbox.conf is highly recommended when you switch versions of Dosbox)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 9 of 10, by MiniMax
Rank Moderator
Moderator
Answer: Not reading the documentation.
_________________
Reply 10 of 10, by wd
Rank DOSBox Author
DOSBox Author
Real answer: people using dev versions, where people==peoplewhoshouldn't. Closed.
