First post, by Sarevok
Hello, I have successfully installed DOS box and mounted both the C: Drive aswell as Cd Drive (E:), and have been able to install two games so far, Fantasy General, and Ultima 7. However, while Fantasy General works, Ultima 7 does not, it states when entering the execution code "Ultima7" that I must remove my extended memory manager or my (EMS). When I type EMS False, it shuts it off, but then tells me I no longer enough memory to run the game. Is there a soultion to this problem?
Smite mightily
