Creating Quick Launches
Reply 20 of 28, by Danielzxzx
leileilol, I don't know but it is something that when I double click the icon, the game will launch dosbox and the game right away without me having to do all this mounting stuff. I know it is possible as it has been done before so yeah. Maybe you know how I can this.
robotmo, 🤣
Reply 21 of 28, by gidierre
Danielzxzx wrote:
Ok, I'm in the configuration file but I don't know what to edit.
(just fyi there's a little edit button on the right side of one's posts to avoid multiplying posts)
alright, what if you take a look at the whole 2 min. tutorial I took that screen from
http://www.megaupload.com/?d=SBHCSWKE
(run the .htm file to view)
in the last third the tips are displayed to edit autoexec in conf.
We often forgive those who bore us, but we cannot forgive those whom we bore. (La Rochefoucauld)
Reply 22 of 28, by Danielzxzx
It worked!!!! Now I have another question. I may have multiple games and I don't want to have to keep changing that when I want a new game so is there a way so that if you click on one file, it will open up dosbox and do commands but if click on another file, it will open up dosbox and do other commands.
Reply 23 of 28, by wd
Rank DOSBox Author
DOSBox Author
FIRST try to find a solution on your own, if you can't figure it out post here.
Reply 24 of 28, by Danielzxzx
I spend a lot of time on this and I had to create an account to find out how to get it so it launches automatically and that is solved but I don't know how to get it so that I can have multiple ones.
Reply 25 of 28, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
look at the readme where it details the command line options for dosbox, especially how to handle configuration files....
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 26 of 28, by Danielzxzx
I looked there and it did not help. Is there some kind of program that can launch programs and have them do funtions and have this saved? That would be good to have it possible to have multiple quick launches.
Reply 27 of 28, by robertmo
they were already mentioned in this thread...
