Graphics Annoyance
First post, by Compucles
My moniter is more than 3/4 times high as it is wide (about 13.25" x 10.75"), so DOSBox gives me letterbox mode with black bars on top and bottom. Changing the resolution settings doesn't help. Is there any way to fix this?
Reply 1 of 3, by robertmo
nothing to fix here, your monitor is just too high
next time buy even higher 🤣
unless you want to remove the huge black bars with aspect=true
Reply 2 of 3, by kalirion
Wait a second, I thought "aspect=true" was meant to preserve a game's original aspect ratio (so that 320x200 games are rendered as 4:3 instead of 16:10)?
Anyway, if your monitor has an aspect ratio setting, turn it off and play the game full screen at a normal (i.e. 640x480, etc) resolution. Or you can probably turn on GPU scaling (without aspect ratio) in your GPU drivers.
Reply 3 of 3, by NoVaTuRiEnT
I've found that using scalers sometimes helps this (see the [render] section in the cfg).
Got mine set to 'scaler=normal3x forced'.
i7 965 @ 3.20GHz | GTX480 | 12GB DDR3 RAM @ 7-7-7-20 1T 1333MHz
2x Velociraptor (600+300GB) HD | 1x WD MyBook 1TB External USB3 | BenQ XL2410T 120Hz
Logitech G9x/G15 | ASUS Xonar D2X PCI-E | Win7 x64 Home Premium
