First post, by predcon
As you know, all games from Good Old Games that require a DOS runtime environment usually come packaged with DOSBox and a wraparound for the game's executable. Unfortunately, they haven't updated their included version of DOSBox since 2008, and so it's up to users to update the packaged version manually. In a similar situation, there are a couple games that run using the ScummVM program, and a user could update said ScummVM simply by downloading the appropriate .zip file and extracting all contents into the game's ScummVM folder. I'm having trouble locating a .zip file, for manual installation, of DOSBox 0.74. All I can find is the installer .exe.
Reply 1 of 8, by SKARDAVNELNATE
You should able to take the files out and mount them in the new version.
Reply 2 of 8, by predcon
Out of an installation program? Mount them?
Reply 3 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Then install dosbox, copy the installed files, uninstall dosbox. Yes you might be allergic to installing stuff you don't want, but that's not taking long
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 8, by ADDiCT
This has been discussed before IIRC. The DOSBox devs are reluctant to provide a ZIP package for some reason. For the record, I'd like to have a ZIP package, too (; .
Anyway, there's an easy solution: you can unpack the NSIS installer with 7-zip. More convenient than installing/uninstalling.
PS: I think the aversion to using installers stems from prehistoric Win9x times, where many (nearly all, in my experience) uninstallers were crap and didn't remove all components, or removed more components than they should. It's a lot better with modern Windows versions, but I'm still using non-installer packages whenever I can. I even install games in a VM and copy them to my "main" OS afterwards where possible. Old habits die hard I guess.
Reply 5 of 8, by predcon
No, see, all I want to do is update the files in a /DOSBOX folder inside a game's main directory. Anyway, I did what I wanted to do by copying and pasting from the /DOSBOX folder inside the program folder for the D-Fend frontend program.
Reply 7 of 8, by leileilol
You could also get DBGL which comes in zip form which has DOSBox bundled with it 😁
Reply 8 of 8, by Sadist boar
Installer is LZMA, so just having 7zip is the thing. Rightclick the installer > 7-zip > open with 7-zip (top-most), then just drag DOSbox.exe and both SDL libs into the needed folder, then confirm replacement.
Sad fat people are never good at using complex programs.
