First post, by Fexel
Hey there,
I wanna make a .bat/.com file which gets .conf file for starting dosbox.exe with, in another folder.
@echo offcd DosBoxcd DOSBox 0.74start dosbox -conf test.conf (Works great if .conf is in the same folder as the dosbox.exe)
I tried:
@echo offcd DosBoxcd DOSBox 0.74start dosbox -conf cd examplefoldername test.conf
Right! Doesnt worked 😉
So, what is the trick to start the dosbox.exe with a .conf file which is in another folder?
Thx for reading 😉
