First post, by eL_PuSHeR
MSCDEX: Failure: Drive-letters of multiple CDRom-drives have to be continuous.
Drive H mounted as CDRom.
However, everything seems to be in order... ???
Reply 1 of 7, by Finster
Rank DOSBox Author
DOSBox Author
multiple cdrom drive letters have to be continous in dos. means you probably mounted two cd rom drives and between those two you mounted a normal drive, eg:
mount c c:\
mount d d:\ -t cdrom
mount e e:\ (not possible in dos !)
mount f f:\ -t cdrom
you may get away with that, but cdrom drive numbers are not correctly assigned, so you might get problems with it if a game relies on that.
Reply 2 of 7, by eL_PuSHeR
No. that isn't the reason. I mounted all hard-disks first, then my two cd drives. One of them is a virtual one. Could it be the reason?
Reply 3 of 7, by Finster
Rank DOSBox Author
DOSBox Author
Mounting a virtual cd-drive shouldnt be a problem. maybe you mounted the two cd drives and skipped a drive letter, like
mount f e:\ -t cdrom
mount h f:\ -t cdrom
the result would be the error mentioned above, cos drive letter g is skipped. Or just tell me how you mount the drives exactly, maybe you found a bug...
Reply 4 of 7, by eL_PuSHeR
I found the reason and it is a very STUPID one IMHO. This is an extract of my dosbox.conf (before the fix):
[autoexec]
# Lines in this section will be run at startup.
mount c c:\
mount d d:\
mount e e:\
mount h h:\ -t cdrom
And this is after the fix:
[autoexec]
mount c c:\
mount d d:\
mount e e:\
mount g g:\ -t cdrom
As you can see, i have three cd-rom drives: F: G: and H: - F is a dvd-rom drive, G is a burner driver and H is a virtual one. Just because i usually don't use G (the burner) under DOSBox i wasn't mounting it. The error comes when drive letters do not match a proper letter sequence, because i was jumping from F to H. Even with the error message, there seems to be no impact in using DOSBox.
Reply 5 of 7, by robertmo
there is "Disable Smilies in this post" option so you can edit the post and set it ;)
You can solve your problem this way:
mount c c:\
mount d d:\
mount e e:\
mount g h:\ -t cdrom
#mount h g:\ -t cdrom
Reply 6 of 7, by eL_PuSHeR
Thanks. 😎
Reply 7 of 7, by Flipblade
I've just started using dosbox and have had the same error crop up and I'm only trying to install 1 cdrom drive
I currently have drive c mounted as c:\games\wc2
Then when I type:
mount d e:\ -t cdrom -ioctl
I get the above error message followed by:-
Drive D is mounted as CDRom
When I type mount it lists as being mounted but Warcraft II will still not recognise it. Any ideas?
