Windows 16 bit program
First post, by ik8ozv
Hi to all,
i am appreciating DosBox for my old Dos program that thanks to it i can run them under windows 7 at 64 Bit.
I want to know if there is also a possibility trough the DosBox to install a 16 Bit program?
If yes which is the procedure please?
Thanks in advance.
Any help will be really appreciated
Enzo
Reply 2 of 10, by ik8ozv
There is non chance with the DosBox?
If i wan to try where to get the program?
Is there any tutorial?
Thanks
Reply 3 of 10, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Read correctly.
Install Windows 3.x in Dosbox, then install the app in Windows 3.x running in Dosbox. If you don't have windows 3.x you need to buy it from ebay or so.
There is a tutorial but it is called guide in the guises section of the forum (as Dosfreak wrote)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 10, by ik8ozv
Can i use also WinXP?
If yes the procedure is the same or is it different?
Thanks
Reply 8 of 10, by ik8ozv
@Dominus Please anytutorial how to install Wndows XP in DosBox?
@collector i have tried XP Mode but it seems it takes long time to start a program, that why i've passed
to DosBox and it seems much better
Reply 10 of 10, by ik8ozv
Ooops orry i missunderstod.
i've red can instead of can't.
please apologize.
