First post, by Dhall
- Newbie
Greetings,
I would like to ask for your help on how to get dosbox to use edirol Virtual Sound Canvas 3.23
I got the VSC installed and I can set it as a default midi device in windows, it also plays midis well, so I think the program works properly.
In the Dosbox readme I read the following:
add a line
'config=id' to the [midi] section in the configuration file, where
'id' is the number for the device as listed by LISTMIDI.
I used the mixer /listmidi command in dosbox and it gave back "Roland VSC" with the id of "1"
In the dosbox.conf, after the [Midi] section I changed config= to config=1.
I tried doom/heretic on general midi/sound canvas and it still uses the windows wavetable.
Where did I go wrong? What did I miss? Thanks in advance!
