First post, by lucky7456969
I've downloaded the driver from vogons dosbox guide section
it is megabuild6, i have set the machine to svga_et4000
language=
machine=svga_et4000
vmemsize=4
captures=capture
memsize=16
Reply 1 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
ET4000 32k/64k/16M is not implemented
1+1=10
Reply 2 of 9, by lucky7456969
Sorry for resurrecting this thread, I realize yhkwong build is capable of 1024x768x16.7M, but what about the driver?
The one found at the guidance section can't do this.
Thanks
Reply 3 of 9, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Then either search a driver that supports this or switch to s3...
Are you sure that yhkwong does support that with the et4000 implementation? Couldn't find anything on a quick glance on his history...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 9, by lucky7456969
I beg your pardon, I am looking into et4000w32 driver
Maybe I would implement that in my spare time
I remember one of your guys put up this driver before
They all vanished after the megaload crackdown
Reply 5 of 9, by Dominus
DOSBox Moderator
W32 sounds suspiciously like Windows 9x driver... But the question remains whether yhkwongs build really supports these high colors for the et4000
Reply 6 of 9, by lucky7456969
I am on my own. I'll roll mine
Reply 7 of 9, by lucky7456969
I've checked the datasheet. Sounds this crippled display card only supports up to 800x600x16.7M which doesn't run good on windows 9x
Reply 9 of 9, by lucky7456969
I am planning to work on et4000w32 emulation
