First post, by DarkRaiiin
Sorry if this is addressed somewhere else; if it is, I missed it. šŸ˜•
When I hit put Dosbox in full screen, the brightness gets REALLY low. If I switch it back, it returns to normal. Is there any way to fix this? It's hard to see. šŸ˜’ Using 0.74.
If any more information is needed, ask and I shall provide.
Thank you for your time! šŸ˜‰
Reply 1 of 13, by leileilol
Maybe your color control goes crazy in 8-bit color. Try changing the output mode to something that's not surface
FUCK "AI"
Reply 2 of 13, by DarkRaiiin
My apologies, but I'd need specific instructions. xD I have no idea what you're on about. :x Not the most tech savvy person around.
Reply 3 of 13, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
in dosbox configuration change output to one of the other choices. In your start menu should be an option to edit the config.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 13, by DarkRaiiin
Erm...do what now who?
I click on options and it opens up a text with a bunch of gibberish.
-edited-
Okay, I figured out how to change it, and tried all of them. The brightness is still REALLY low for all of them.
Reply 5 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Did you try the controls on your monitor? some of them save their settings per resolution.
1+1=10
Reply 6 of 13, by DarkRaiiin
What would I change? I know that the brightness/contrast is maxed.
Reply 8 of 13, by DarkRaiiin
I just know that it's at 100. It doesn't say anything about resolutions.
Reply 9 of 13, by robertmo
what is your operating system, graphic card, monitor type?
check what happens if you set in dosbox's config
fullresolution=0x0
with different output types
Reply 10 of 13, by DarkRaiiin
Windows 7 x64, ATI Radeon HD 4200, monitor says "generic Non-PnP monitor". It's a pretty old, crappy emachines monitor.
Putting it to 0x0 just keeps it at the normal size, while having black all around it to technically make it full screen. I'd like it to actually be full-screen.
Reply 11 of 13, by robertmo
try different outputs now
Reply 12 of 13, by DarkRaiiin
It's still a little dark, but for the most part, that solved the problem. Thank you for your assistance.
Reply 13 of 13, by robertmo
is monitor flat or now? what model exactly? how old is it?
try to change its drivers to windows' default Plug and Play Monitor
