First post, by Crimsonite
I see a thread on here that says DosBox is no good for non-gaming apps. Well that's just bullcrap. I started a novel twenty two years ago on an old AT computer running Dos 6.2 and the Q&A2 word processor. After many years when everything associated with that computer was obsolete, it was stolen. All I had left was the old Ditto Easy QIC tape backup with the App and files on it. Recently I found an old AT with Win 98 on it, and found a Ditto Easy. Amazingly the tape was still good and I restored Q&A2 and the files. Then I copied everything and moved it to my new laptop. Immediately I went to DosBox and mounted the drive and ran the .bat file that is necessary to run Q&A2. It ran perfectly and still does so that I am able to complete my novel. In case you are wondering why all the trouble - it is impossible to get Q&A anymore, anywhere; and no modern word processor will read Q&A files.
