Screeching when running DosBox
First post, by marooned_on_mars
I've never encountered any app/program to do such a thing, but whenever I run DosBox I hear a continuous high-pitched screech/hissing through my headphones (I can also hear when the HDD spins, but it's not that loud, this probably indicates an issue with the way the jack sockets are wired) but also up close to the unit. It's not extremely loud but it can still get quite distracting and annoying after a while (much like how annoying are bad camcorders when they leave behind a sort of a ringing sound in the background when recording). At first I thought it might be an issue with SDL and my rig, but that's not the case, as I've tried other SDL apps (like ScummVM) and this doesn't happen.
Here are the following things that I tried as a way to diagnose:
  • DosBox on both Windows and Linux. It's a bit less louder on Windows, but still annoying.
  • Compile DosBox myself from either 0.74 source code and latest SVN
  • Used ykhwong's builds
  • Got DosBox from the Debian repos
  • Increased/Reduced cycles. Interestingly when I would go below 2000 cycles, the pitch would go lower progressively
  • Changed between video output types
  • Changed between the core types
  • Changed between machine types
  • Changed audio sample rate
  • Changed blocksize
  • Disabled all sound sources
None of the above did change anything (except with the cycles example), so now I'm sitting here and wonder what exactly is causing this. Any help would be really appreciated.
Reply 1 of 44, by leileilol
Sounds like electrical "thinking noise" interference. Onboard audio, right?
Reply 2 of 44, by marooned_on_mars
Yes, that's a neat way to call it, and yes I'm using onboard audio.
Is there anything I could fix software-wise?
Reply 3 of 44, by ElectricMonk
By default, DOSBox simulates a SB-Pro/SB-16 just fine, provided you've set the IRQ and DMA correctly.
Try BASSMIDI.drv. I can use it to simulate a Roland GS synth, and SB-16. No screeches.
MUNT, if you want to use to simulate an MT-32/CM-32L for synth music.
*EDIT*
BTW, I love your avatar of Mitzy giving Shin the business! Shame Funimation lost the rights, after the Japanese rights holders FLIPPED, when they realized they were re-versioning it as rated R. I've got every episode saved on my media drive . 😜
Reply 4 of 44, by marooned_on_mars
Thanks for the answer, but I think you misunderstood the question/problem 😀
I compiled both MUNT and MUNT-less versions of DosBox by the way.
Reply 5 of 44, by ElectricMonk
Ah, ok. I;m using the Dosbox 074, and the standalone munt driver. Still, no screeching here. There's gotta be a misconfiguration in the sound somewhere.
Does it do it in every game? Have you tried selecting other sounds cards, besides SB-16? Could the game you're playing have corrupted sound files, or need patches like certain titles do with ScummVM?
There's gotta be some commonality we can narrow this down to.
Reply 6 of 44, by marooned_on_mars
It happens when I'm not in any game as well (just in the command prompt), also:
Reply 7 of 44, by ElectricMonk
Gotta admit, I'm stumped on this one. The noise doesn't happen any other time, does it? Like a CMD prompt, VTY terminal, anything?
*EDIT*
And you uninstalled Dosbox, wiped out all the folders/reg keys, re-installed it, and it still screeches at the bare prompt? What's your Dosbox.conf look like?
*EDIT 2*
I should've been a Scooby Doo character. I love a good mystery.
Reply 8 of 44, by marooned_on_mars
Not sure what a VTY terminal is, but no, this screeching occurs only while DosBox is running, doesn't matter which version either.
I suspect this screeching might come from either the CPU or integrated GPU.
I was using a "portable" version of DosBox on Windows. I doubt this would fix anything though 😀
Wouldn't object to that 😜
Reply 9 of 44, by ElectricMonk
A VTY is a virtual terminal, like Putty or SecureCRT. It's used to "remote in" to devices and get a CLI, to access a device (server, router, switch, vpn gateway, etc...). I don't see why the CPU or iGPU would cause the screeching. It would do it ALL the time, if that were the case, I'd imagine.
I've never tried the "portable version" (no need to, even on my craptop), but trying the regular stable release is worth a shot. And please post the dosbox.conf file. Maybe there's a clue in there.
Reply 10 of 44, by Jorpho
Have you tried a very old version of DOSBox, like 0.60 or something? Perhaps if the sound is missing from the oldest version of DOSBox you can find, you can slowly work your way up to the current version and see if it might be associated with the introduction of a particular feature.
The "talking parrot" fix springs to mind, but that's probably not quite related.
Also, I don't suppose you notice the sound whenever you just display a large black window on your monitor, do you?
Reply 11 of 44, by marooned_on_mars
Here you go:
This is basically the "standard" config file for me: http://pastebin.com/JUzLUhT3
I would advice you to switch to SSH, much more secure 😜
Not really, it probably depends on how the compiled program is executed by the *PU.
It *is* the regular stable version, just that instead of using an installer, I just extracted it's contents out 😜
Still wouldn't make a difference as it didn't change anything when I used the official Debian build of DosBox.
Will try that on Windows, I doubt I'll be able to find deb packages of that version, or be able to compile the source code (considering how much gcc has changed since then).
I don't know how that is related indeed, all I remember of it was a creepy demo with an EGA-drawn parrot that keeps talking 🤣
Er, no?
Reply 12 of 44, by ElectricMonk
Here you go: This is basically the "standard" config file for me: http://pastebin.com/JUzLUhT3 […]
Here you go:
Um, Putty IS an SSH client, as is SecureCRT, but they still access VTY lines, and are called Terminal Emulators. SCRT is like the leather LaZboy of terminal emulators. It's paid software, but it's worth every cent. Once you use it, you'll never want to go back.
Reply 13 of 44, by ElectricMonk
Here you go:
The only difference in my conf from yours is:
mapperfile=mapper-0.74.map
cycles=auto
cycleup=10
cycledown=20
blocksize=1024
mpu401=intelligent
mididevice=default
midiconfig=0
(there are NO MT-32 entries in my conf. Probably since I'm using the standalone Munt driver
oplemu=old (for SB emu)
gusrate=44100
Otherwise, everything else in your conf looks like mine.
Reply 14 of 44, by collector
Unlike some of the frontends like D-Fend Reloaded, DOSBox does not use Registry entries. Even the DOSBox installer does not. The only trace of DOSBox that you will find in the Registry will be from Windows itself, like in the MRU cache. Outside of the Start Menu DOSBox folder from the installer and the DOSBox folder itself, the only thing that it will write files to is in the user's DOSBox %LocalAppData% folder and the user's VirtualStore if DOSBox is installed in the %ProgramFiles% directory.
Given this, the PortableApp build of DOSBox has a little advantage and is even a bit silly.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 15 of 44, by Jorpho
I mean, at the time I think there might have been a change committed to the DOSBox source that might conceivably have resulted in DOSBox producing a constant hissing noise. But I'm not sure the change mentioned in that thread was ever actually committed, or even if it would have resulted in any change in the DOSBox audio output.
Reply 16 of 44, by ElectricMonk
collector wrote:
Unlike some of the frontends like D-Fend Reloaded, DOSBox does not use Registry entries. Even the DOSBox installer does not. The […]
Oh, ok! Good to know! I'm still relatively new to DosBox, so I was unaware. Thanks for the heads up! 😁
Reply 17 of 44, by Qbix
Rank DOSBox Author
DOSBox Author
how about nosound=true ?
and possibly other SDL applications like scummvm
Water flows down the stream
Reply 18 of 44, by Jorpho
That was mentioned already.
Reply 19 of 44, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Regardless whether fullscreen or windowed mode? My old flat screen is making high pitched noises through its speakers when the screen is really bright. But not nearly as loud as you make it sound. Turning down brightness helped in these cases.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
