First post, by MabusRaeen
Yep, it's done. To many changes to list here.
Download it from http://members.home.nl/mabus
Enjoy!
Author of D-Fend, a DOSBox frontend.
D-Fend homepage.
Reply 1 of 6, by robertmo
One thing:
Video Card should be in Environment section as it affects compatibility unlike whole General section.
Reply 2 of 6, by MabusRaeen
Yeah good point...
Bugger.
D-Fend homepage.
Reply 3 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
well you got your news item.
Let's hope it makes dosbox a bit more accessable 😉
Water flows down the stream
Reply 4 of 6, by Trig
Wow, that was fast.
I, for one, use D-Fend all the time. Makes DosBox so easy to use.
Thanks!
Reply 5 of 6, by priestlyboy
Wasn't that fast. Took a couple weeks of beta testing it. 😜.
Ieremiou
Helping Debug DOSBox.
Reply 6 of 6, by MabusRaeen
Couple of week? Oh why don't you bugger off 😜.
Actually I started rewriting and orginizing D-Fend LONG before 0.62 release. The actual adaptation to 0.62 only took a day 😀 at most but D-Fend was practically rewritten from the ground up so it required a lot of testing.
D-Fend homepage.
