Mounting directiories as CD-ROMS
Reply 20 of 29, by MiniMax
Rank Moderator
Moderator
Anonymous wrote:
still wont work... seems like the letter "e" is the only letter i can mount
as cdrom drive. Or maybe I just can't mount more than one directory.
This does not make sense, Anonymous. Are you saying that this does not work:
mount c c:\
mount e c:\phan1\cd1 -t cdrom
e:
dir
mount d c:\phan1\cd2 -t cdrom
d:
dir
Edit: Fixed an error in the mount command. -type should be -t.
_________________
Reply 21 of 29, by Guest
it doesn't work and i have no idea what i'm doing wrong...
i can still play the directory thats mounted with "e" but not the one that's
mounted with "d" or any other letter
Reply 22 of 29, by MiniMax
Rank Moderator
Moderator
Did you type in the commands exactly as I wrote them?
Yes or no?
_________________
Reply 23 of 29, by Guest
yes, I have used that exact setting, and the game detects the files
of cd1 but when I reacht the point of swapping discs, the game still can't
find the cd2 dir.
I have checked and I am 100% sure there's nothing wrong with the files.
This is the autoexec line I use:
mount c c:\
mount e c:\phan1\cd1 -type cdrom
e:
dir
mount d c:\phan1\cd2 -type cdrom
d:
dir
c:
cd sierra
cd scarydos
phcd
Reply 24 of 29, by MiniMax
Rank Moderator
Moderator
Anonymous wrote:
This is the autoexec line I use: […]
mount c c:\
e:
dir
d:
dir
Well, if this works - in particular the dir commands, then DOSBox can mount and see the files. So it was not entirely accurate when you said "Or maybe I just can't mount more than one directory" 😀
Have you tried switching the mount and drives around (D = CD1, E = CD2)?
Oh - And I think you should change '-type' into '-t':
mount D c:\phan1\cd1 -t cdrom
mount E c:\phan1\cd2 -t cdrom
How do you start DOSBox?
Can you use CTRL-F5 in DOSBox to capture a couple of screenshoots when the game asks for the 2nd CD?
_________________
Reply 25 of 29, by MiniMax
Rank Moderator
Moderator
FYI: Some people are discussing how to get Phantasmagoria 2 to run here.
_________________
Reply 26 of 29, by tomlow
hello Minimax, I just recently logged in so from now on i'm "tomlow"
(just to let you know).
thanks for the help so far... I will try again and capture some screenshots.
Reply 27 of 29, by tomlow
Again, it didn't work, I switched the letters but the letter "d" just won't mount. I don't start dosbox in an abnormal way, i just click on the Doxbox.exe icon. This is the line i used this time:
mount c c:\
mount d c:\phan1\cd1 -t cdrom
d:
dir
mount e c:\phan1\cd2 -t cdrom
e:
dir
c:
cd sierra
cd scarydos
phcd
and I added a screenshot when the game asks me to switch cd's
Reply 28 of 29, by MiniMax
Rank Moderator
Moderator
Okay - since the menu do not allow you to specify drive D: or drive E: you have to use the same drive-letter for both CD's.... Which means: No copying to the harddisk, and back to mounting the physical CD-drive (which you can eject & swap):
mount D "X:\" -t cdrom
or
mount D "X:\" -t cdrom -ioctl
And then (as I wrote earlier):
1. Use the real, physical CD's
1.1) When the game wants CD #2, eject CD #1.
1.2) Insert CD #2.
1.3) Wait for the drive to spin up and spin down (watch the lights).
1.4) Press CTRL-F4 (which should cause DOSBox to re-read the CD-info.
1.5) Tell the game (Phantasmagoria) that you have changed CD's.
_________________
Reply 29 of 29, by tomlow
wow dude! it really worked!
it was the mount D "X:\" -t cdrom -ioctl code that made it work.
BIG BIG BIG THANKS!!
this shows the use of these forums, i will help as many people as i can
and try to run as much games under xp as possible!
thumbs up for vogons and dosbox!
