First post, by Tarl
So I downloaded Daggerfall from Bethesdas website and also downloaded dosbox and put them on a flashdrive. Yesterday after a couple of hours I got Daggerfall to install but could get no further. I figured i did something wrong deleted both and reinstalled and now today when I try I did the exact same thing as last time but now I can't even install Daggerfall. Can anyone help me or tell me what I am doing wrong or what I can do to remedy the problem. I followed instructions from a video and used these prompts,
mount c E:\dosgames -freesize 1000
mount d e:\dosgames\dfcd -t cdrom -label Daggerfall
Like I said it ran the installer yesterday when I realized that after I type in E: to bring it up I had to type in dfcd\install for it to run the installer.
Is it impossible to run on a flashdrive or am I doing something wrong because like I said when I tried today it said E: is not valid and needs to be mounted.
Reply 2 of 8, by leileilol
You could do it relatively if dosbox is located on the same partition.
Say you have DOSBox in
E:\dosgames\dosbox
And you can have these as your mounts:
mount C: .\..\
mount D: .\..\dfcd -t cdrom -label Daggerfall
So then it'll work on whatever drive letter the host OS assigns your flashdrive to.
I should mention that it's possible to mount the root of a drive without warning by supplying enough ..\'s
FUCK "AI"
Reply 3 of 8, by Tarl
Oh, see I had DOSBox in a separate folder, so if I have it in my dosgames folder then it should work then?
Reply 4 of 8, by leileilol
You don't have to move it there. It's just a way for it to be 'portable'. It might be a bad idea with stdout.txt possibly wasting writes on it though
FUCK "AI"
Reply 5 of 8, by Tarl
Nevermind just tried it, it still wont work says C:\>install is an illegal command and when I try C:\>dfcd\install it still won't work. This is very frustrating and add on to the fact I haven't used DOS commands in 20 years is making it worse.
Reply 6 of 8, by Jorpho
Just do a Google search for "daggerfallsetup" and you can find a nice pre-configured package that's all ready to go.
I don't know what you think you're doing, but a command like "dfcd\install" will generally not work as expected, as it runs a program from a different directory from any of its support files. Generally you would want to type "cd dfcd" and then "install".
You should probably review the 60 Seconds Guide.
Reply 7 of 8, by Sammy
create two seperate dirs:
E:/dosgames
E:/cdimages
put your daggerfall image (i think its dfcd.iso ??) to e:/cdimgages/dfcf.iso
then
mount c e:/dosgames (+ parameters like freesize, etc)
mount d e:/cdimages/dfcd.iso (+parameters like type, label, etc)
then you should have in dosbox a drive c: which is empty.
try:
C:
dir
and your cdimage at D!! not E!!
cd D:
dir
install
Reply 8 of 8, by Jorpho
That would be "imgmount", not "mount", and it does not generally require parameters.
Sammy wrote:
cd D:
And that would be "D:". "cd D:" will not work, ever.
