First post, by MPekkola91
Hello, everyone! I've got a problem here.
My problem is this: I'm trying to record gameplay videos with "Mirillis Action!" on DosBox, but DosBox crashes on a startup, while trying to load up DosBox and Mirillis Action!
Is there any idea to solve this problem? Any help is appreciated 😀
Thanks!
Reply 2 of 5, by MPekkola91
Does that mean, that i need to talk to the Mirillis team about this issue?
Reply 3 of 5, by Jorpho
SDL is an extremely common library used by many applications. If Mirillis does not work with SDL, then yes, you should probably contact the Mirillis developers.
The Windows port of ScummVM also uses SDL, if you need another application for testing.
Reply 5 of 5, by Jorpho
My favorite is BB Flashback Express, but why not just use the screen recording functionality built into DOSBox?
