Reply 20 of 23, by JHawx
- Newbie
but putting those commands in order of:
choice /c:123x /n Choose one of [1,2,3, or X to exit]:
or
choice /c:x123 /n Choose one of [1,2,3, or X to exit]:
results short execution. I meant that it acts as choise isnt there. The last code will be run, others dont care. I mean that it could be great to use letters for diffirent games, but if you need to use alternative methods to diffirent startups
like in Master of Magic, there is magic command that launches the game (binded to "M" letter) there could be other setting also. The wizard command sends the game directly to last savegame state (bybasses the start menu totally) would be bind to number (number "2")
is this hardcode error? or is there actual rule that you cant mess up the letters to numbers?any bybasses to this criteria? 😁
