Dominus wrote:twick: I started a guide for Windows 3.1x on Dosbox at Windows 3.1x DOSBox Guide, maybe that helps in choosing/finding the drivers.
Yea, it's a must read for anyone interested in Win 3.1x
I can't post in that forum so ill ask you about a couple things here.
---- Soundblaster
I went to soundblaster.com and got the driver for "Sound Blaster 16"
#3 "Windows 3.1x drivers for the Sound Blaster ISA 16/32/64 cards (634.62 KB)
My question here is:
They list "Sound Blaster 16" as well as "Sound Blaster Wave Effects"
There is also two drivers listed "sbbasic" and "s16dw3up.exe" should there be a suggested to use here? We could test both and say either of these should work..... For a new user they may be a little confused on witch ones they need.
I have Win 3.11 for work groups installed and it list Sound blaster 1.0 and 1.5 should we give a suggestion on witch one to choose from?
Also here is a direct link to there downloads section where you select your Lang.
http://www.soundblaster.com/language.asp?sDes … pport/downloads
--- Win32's
Here is a nice link : http://stephan.win31.de/w32slist.htm
--- a site with downloads,
Here is another one : http://oldfiles.org.uk/lightspeed/main.html
--- graphics drivers,
I tried to install the Graphics drivers after I had already installed Win 3.11 and ran into trouble. This could be because i'm using Wine 😀 But anyway I think its best to select "Manual" install and install the graphics drivers when you install Win. It works allot better that way for me anyhow....
A good read for those with some time to burn!
Part #1
http://www.osopinion.com/modules.php?op=modlo … order=0&thold=0
Part #2
http://www.windowsitpro.com/Article/ArticleID … /4494.html?Ad=1
Cheers,
Tom
