First post, by gerard
Thanks for writing dosbox.
Thanks to it, I can run my Psion Series3 emulator (s3aemul) for the first time in a windowed multitask environment (neither dosemu, nor win 95 nor vmware could do it) . It is only a bin slow (slower than native msdos on a...p166 when running dosbox on Athlon 3GHz), but correct for the usage.
(See http://www.delafond.org/psilin/index.html#emulateur)
A few questions :
-the settings of my french keyboard is a pity. Only the letters are good. The numbers and other signs are "random". I saw I could use a keyboard layout from freedos. Is there a complete explanation ? Is there a good explanation on how to use the keyboard setting utility, specially with Shift and AltGr functions ?
-the background of the Psion emulator is grey in windowed mode (see my webpage), but white in Fullscreen mode. Is there a solution to get it always white ?
-I would like to use a dos window of 480x160 pixels (the size of the Psion emulator). Is it possible ?
-I cannot access to F11 and F12 keys. Why ?
Thanks again for this amazing job !
